New Brakes Shaking, Help Please!!!
Discussion in 'Wheels / Suspension / Tires / Brakes' started by 91_civic_si, Oct 23, 2007.
  1. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    Just did whole brake system, Hawk hps, Brembo blanks, rebuilt caliper in front. Out back brembo drum, new shoes, cylinder, springs. Also did Goodridge stainless lines. This is on a 91 civic si. When going over about 30 and lightly pushing pedal I get vibrating. Do you think rotors are warped (didnt check runout due to being new rotors) or do stainless lines need a break in or something? Help me please!!!
  2. E_SolSi
    i would first make sure there isnt anything behind the rotors where they meet the hub
    often there is crap built up there from the old rotors and that will cause them to feel warped
    hit the face of the hub with a wire brush to clean everything up
  3. 91_civic_si
    Wasilla, Alaska
    ok, i will check that. Any other ideas?
  4. norcalgsr
    NorCal
    I really doubt that the Brembo blanks would be warped out of the box since they're real good quality parts. I'd do what E said and also make sure to torque your wheels properly that can warp rotors if they aren't torqued evenly to the right spec.
  5. 91_civic_si
    Wasilla, Alaska
    It turns out the the brembos were warped new out of box. I cant return them because they are used now. Had them turned and still getting a little vibration. I now really really know that I have the worst luck.
  6. Hasid Lafre
    Hasid Lafre Master of the obvious
    Where did you get them from? regardless they should take them back cause the only way to tell if they are warpted is to actually drive on them.
  7. 91_civic_si
    Wasilla, Alaska
    tire rack, they wont take them back after being used. supposed to measure runout before installation. there goes my wishful thinking
  8. E_SolSi
  9. norcalgsr
    NorCal
    That's shitty I've never had a single problem with Brembo's..
    Are you putting your wheels on with a torque wrench?
  10. 91_civic_si
    Wasilla, Alaska
    yes, every single thing done has had a problem. I have come to realize that I do have the worst luck in the world.
  11. Hasid Lafre
    Sell them on ebay and buy from a reptuable place.
    I wouldent buy a damn thing from tirerack, even if my life depended on it.
  12. 91_civic_si
    Wasilla, Alaska
    Thanks but no thanks, you have not helped me one damn bit with that shit that you talk. Why would I want to sell someone stuff that is known to be damaged just to ruin my 100% reputation on Ebay? Tire Rack is a very reputable place. Are you stupid??? It is people like you that make others worry about their Ebay experiences. If I need your help I will ask for it so stay out of my threads. Thank you in advance. Thanks to everyone who was actually helpful.
  13. norcalgsr
    NorCal
    :werd:
    I wanted to say the same thing but you beat me to it!
    1 person likes this.
  14. 91_civic_si
    Wasilla, Alaska
    I am just glad that I am not alone
  15. JermBizzle
    JermBizzle Active Member VIP
    I know this post isn't hardly related to your issues, and i'm sorry to hear about your problems with the brembo's, but shit happens I guess.
    What I was going to say is, after you've used this setup for a while, you might want to swap to rear discs from a 90-93 integra, its a rather easy swap with great benefits!
  16. norcalgsr
    NorCal
    Yeah I've seen more than a few posts of BS from that guy.. I wish I could help you more with your problem but I don't know where to go from there. Maybe try to get a manager of Tire Rack on the phone and talk them into fixing the problem for you? It's worked before at other places local to me in the past...
  17. norcalgsr
    NorCal
    I'm sure he already knows about that conversion, and it doesn't relate to the original post at all.
  18. JermBizzle
    Well maybe, just by chance, he doesn't....just trying to help someone out. Read the first part of my post and it says that i'm well aware that it doesn't relate to the original post. :)
  19. norcalgsr
    NorCal
    Didn't see that before sorry.
  20. JermBizzle
    Didn't think so.
