new here from maine. H22 eg
Discussion in 'Auto Multi-Media' started by eg6-jarhead, Feb 24, 2011.
  1. eg6-jarhead
    eg6-jarhead New Member
    hey guys & girls.
    im new here but not to hondas.
    there isnt a day that i dont think about going faster.
    i believe im a true honda head :)
    i'll start my intro with some hondas that ive owned/currently own.
    first car:
    1994 civic dx hatch 5spd
    charcoal
    bought it at 16 yrs old.
    swapped in a d15b cause the b7 was smokin like a bastard.
    man i miss how simple my life was when i had this car :)
    mocked up my first turbo project on the hatch:
    then the 1st hatch wouldnt pass inspection.
    so i kept it as a parts car and bought a red 1995 dx hatch (riced).
    i removed the halo lights, eyelids and front mount intake lol.
    then i boosted it with the kit i had mocked up on the black hatch. car went 14.6 @ 94 1/4mile.:
    then i built a d16z6 for the red hatch. typical eagle/srp combo.
    never got it running right. sold the turbo stuff, and kept the built block.
    sold the red hatch. bought a white 1992 white cx hatch. still own this one, its my r&d whore.
    swapped a stock z6 into the white hatch cause i couldn't deal with the 8 valve that was in it haha.
    car ran 15.5 @ 94 1/4mile just how it looks in this pic:
    then i boosted the stock z6 with a 14b. car ran 9.3 @ 76 1/8th mile.
    no traction due to crappy track prep:
    then i thru the built z6 block that i had in the red hatch in it.
    car made 300whp on 20psi. never got to track it cause i cracked a sleeve:
    now im going turbo h22a with a gt3582r turbo. still in the making.
    and a quick pic of my old daily driver wagon and my jeep:
    1991 wagonthing. stock everything except fart can and tow hook. cut springs and knock off 15" slipstreams:
    1989 cherokee with wayyyyy to much to list lol.
    enjoy!
    -jack
  2. eg6-jarhead
    so i cracked a sleeve on my d16 in 2009 on 20 psi. after that i got out of the sohc game, and picked up a jdm h22a with 70k on it.
    put the car on the road in august of 2010, n/a car went 13.3 @ 104. not fast enough.
    this winter there are major changes happening in the set-up.
    current mods/parts list:
    jdm h22a 60,000 miles on it
    innovative billet aluminum engine mounts
    type s cams
    kaizen speed balance shaft eliminator kit
    arp headstuds
    skunk2 intake manifold
    aftermarket intake
    brand new headgasket
    brand new timing belt
    type s crank pulley (1 groove)
    12lb flywheel
    dragger clutch, 6 puck sprung hub
    dual diaphram pressure plate
    custom axles
    full integra disc brake swap front and rear
    energy suspension rear trailing arm bushing
    blox lower control arms
    rear lower and upper tie bars
    front upper strut bar
    skunk2 coilovers
    brand new rotors and pads front and rear
    brake line tuck
    charcoal canister removed
    full 3 inch exhaust from the collector back
    flowtech chambered muffler
    summit racing resonator
    1000cfm slim fan
    dual core radiator
    new alternator
    new plugs
    walbro 255lph fuel pump
    buddy club seats
    stripped interior
    tach in gauge cluster
    vdo oil pressure gauge
    integra front sway bar
    4-2-1 stainless header
    spoon mirrors
    rota circuit 8's powder coated white
    bfg kdw's 205 50 15
    6k HIDs
    SS brake lines
    15/16ths master cylinder
    carbon duckbill
    im sure there is a lot im not remembering.
    the car has a custom tune on it via crome free. i still get 30+ mpg highway
    best time to date is 13.393 @ 104mph.
    this winters project: BOOST.
    for 2011:
    blueprint mfg sleeves
    manely rods
    cp pistons
    skunk2 pro 1 cams
    skunk2 cam gears
    arp mainstuds
    gt3582r 3" vband exh-housing
    big FMIC
    supertech valve train
    hks ssqv
    rc 750's
    custom built topmount manifold
    twin 38mm wastegates
    turboxs dual stage boost controller
    lsd
    24.5x10 slicks on lensos
    I JUST WANNA GO 10'S!!! SO BAD haha
  3. eg6-jarhead
    pics of this winters progress: (2010/2011 winter)
    skunk2 pro 1's with gears
    garrett gt3582r
    manifold pieces: (disregard hx35 turbo, sold it and got the garrett)
    how it sits currently before turbo
    enjoy!
    thanks
  4. 99sidude
    Ohio
    AWESOME! The car looks sick dude. Thanks for sharing your story. I'm looking forward to the boosted h22 build. You don't see those very often. I see that you joined 3 years ago and just now made your first posts:) Welcome
  5. eg6-jarhead
    yea haha amazing i remembered my user name and password.
    i joined back then when i was buying/selling stuff. now im here for good ;)
  6. hondafreak513
    hondafreak513 New Member
    O hi O
    Nice build man, started out at the bottom and now worked your way up... Keep the pics rollin I would love to see a turbo H22 Hatch...
  7. eg6-jarhead
    thanks
    ill throw some more pics up soon..
  8. krz12
    krz12 New Member
    hey guys new here and also new to the whole forum thing. jarhead, quick question have u had any problems driving the h22? i have a 94 integra with a h22 and im having a couple problems just wondering if u could share some info..... thanks
  9. eg6-jarhead
    i fixed every problem i was having.... shoot away
  10. krz12
    krz12 New Member
    its hard to explain but today when i went to drive the car it wouldnt even make it to 3000 rpm and it felt like it was choking, but it didnt stall at all and it did it in every gear but then the check engine light came on and it didnt do it anymore. i didnt check the code, its obd1. any ideas?
  11. 95b16coupe
    95b16coupe New Member
    ct
    Awesome build dude. Keep us updated with progress.
  12. eg6-jarhead
    maybe an electrical issue like a ground or something. especially if it is intermittent. try to get the code next time
