Doing a B16A into a 1990 Civic Si. The B16 is a OBD 0 sir 1. It has had the following changes:
Block has been bored .010"
CP pistons (10.5-1 comp)
Eagle rods
Head and block have been decked, comp should be around 11.0-1
Mild port job on head,
5 angle valve grind
Brian crower stage 2 cams, valve springs and retainers.
Adjustable cam gears
Cold air intake
2.5" mandrel bent exhaust with Magnaflow.
Thanks for hanging in there so far, here is my question;
What tuning will I need to do with this set up? I have a Walbro 255 pump, will just increasing fuel pressure be enough? Do I need a standalone EFI system (hondata) or a VAFC? I have a wideband a/f sensor so i'll be able to see if its running lean. I haven't run the car yet, I wanted some help with the tuning before I start it up. Its a mild setup, I hope I can get away with just a fuel pressure increase but ANY help would be appreciated.
Thank you for looking.
Eagle rods
5 angle valve grind
Cold air intake
