new ls vtec is alive!
Taco15
I wear stretchy pants
so it finally started! after a month and a half of waiting and spending cash. got 2 questions though
breaking in till about 300 miles.? is that correct ohhh and with no vtec. Due to the ecu still being obd0 and tuned for the previous build which means i'm running lean. Onece i break it in i'm putting in the p28 chipped and tuned and then its go time vtec !
also should i be worried about a 2nd o2 sensor code since i dont have one? you can check out my rex by clicking on my albums. I'll post more recent one soon
old setup
stock head with gsr cams
stock block with pr3 pistons
new setup
ENTIRE forged 11.3.1 compression eagle rotaing assembly
h beam rods
p&p'ed head with skunk2 springs,retainers and stager2 cams thanks to Mike bergy :worthy:
FEELS GRAET AND HAS ALOT OF TORQUE! (compared to the ols setup) I hope i can hit the 200hp mark.
pics of my 2 honeys
https://hondaswap.com/forums/uploads/11..._312_768716.jpg
https://hondaswap.com/forums/uploads/11...57_312_2413.jpg
crappy pic of the crappy exhaust. I'm the market for a new one
https://hondaswap.com/forums/uploads/11..._312_141820.jpg
as you can see i have no front turn lights :cry:
https://hondaswap.com/forums/uploads/11..._312_667039.jpg
LS -VTEC MOTOR. old pic but new internals.
https://hondaswap.com/forums/uploads/11...7_312_34415.jpg
Quoted post[/post]]
old setup
new setup
h beam rods
run the right ecu from the get go, dont wanna run to lean.
thanks for the ifo. I was told that its actually pretty good to run a tad bit lean. As soon as i get some money i'm going to 0bd1.
Congrats bro looks good post the numbers when you get to the dyno.
Quoted post[/post]]
yea becareful when running lean. lean = hot. too hot can be disaterous.
thanks guys i was told that. I constantly check the temp gauge and check the fluids EVERY morning.So far everything if great!
