i maybe wrong or have this backwards so dont bash me too hard lol .. but wouldnt tht be the pilot bearing squeaking unless the clutch is pressed? jus curious bro..
Mine is the throw out bearing (based on symptoms). I can touch the fork with my hand and make the noise go away (b/c the bearing needs pressure on it or it makes noise spinning freely)
His situation is different then mine so I am not sure if its the problem but if he's are getting a new clutch...OEM throw out bearing is a good decision in any event.
OP: You might look into a main bearing and seals too (but research or use Helm's for install)
