New P28 Chip, Obd2 To Obd1 Conversion
Pewble
I need to convert my OBD2 to OBD1, For two reasons. One is I recently installed a High-flow Cat, and I need to bypass the O2 sensor so my check engine light is disengaged. Second reason is because instead of buying a simulator to emulate this effect, OBD1 will not check this, and then conversion can offer a horsepower advantage because OBD1 is better and because I am getting a Skunk2 / Or Mugen Chipped ECU combined with the OBD1 conversion ( The chip converts and acts as an ECU, and is a P28 chip ).
Another question...
Mugen or Skunk2 ECU program? which is better? .... my engine has stock internals ... THANKS.
the skunk2 and mugen are good, but alot of claimed mugen chips arent really the mugen curves, so unless u can verify that its a mugne copy, get the skunk2
