Citizen_Insane
Ok, so a while back I tried to take off my rear shocks and found that the bolts at the bottom that connect the rear shocks to the rear trailing arm are seized inside the bushings (they have a metal insert) and won't come off. I already tried the Hammer + wd-40 trick....didn't work. I can turn the bolt, but all it does is bend the mount on the shock outward as I turn (there is a nut welded to the plate that comes down to hold the shock in place over the bushing). So...
1. How do I get the damn things off?
2. I assume I'll need new bushings, are these the right ones? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
