new swap
Discussion in 'HYBRID -> EG-EK / DC' started by colombian_jam, Oct 30, 2006.
  1. colombian_jam
    colombian_jam New Member
    miami
    well guys these weekend i get a little be crazy and i decided to do a swap on my car i have a EG stock and my friend was give away his LS engine so i decide to do it everything was mad easy fo r be my first swap everything was bolt on even the wiring harnes the engine came out of a 1998 LS 98000 MILES THE ONLY THING WAS the at the tranny has a little a wrecled noisy so i will need one soon but everything is perfect .....
    anothe here i get a little confuse the AC bracket its to big for the compresor that i have its any bracket that fit on the car and i can still use my AC compresor i dont wannt to change compresor all that i want is a bracket that fit my compresor .....
    thank you for your help
    and believe me these swap has power i love so far
  2. EG6Civic83
    EG6Civic83 New Member
    get you the AC bracket from Hasport for B series swaps into a D series chassis. Its like $165 which isnt bad. you will be able to use your stock AC compressor on your new LS motor.
  3. colombian_jam
    miami
    i was searching and i found if i use a del sol vtec 1994-97 ac bracket it willl fit perfect its that tue
  4. EG6Civic83
    i am not sure... i think you can get that bracket from honda and it may fit. i just swaped a B16 into my EG and was able to retain P/S by using the B series pump and bracket and the P/S hose and tank neck from my D series. the AC was different though. I couldn't use my compressor with the AC bracket on my B series. my advice: get the compressor and stuff from your friends LS Teggy and use your D series lines. could save you some money.
  5. colombian_jam
    miami
    thank you but we junk the car already so i will need a bracket that fit on mi compresor anyone
  6. EG6Civic83
    ahhh.... well i dont know then. i know my motor is the JDM equivalent of the USDM del Sol motor and the AC bracket didn't work for me. maybe it will work for you. i would junk yard search first though because those cars have to be around and the bracket isn't hard to remove. You'll need a 17mm socket that is 1/2 inch drive and a decently long socket wrench, 1/2 inch drive, to make things easy. you may also need a 14mm and a 12mm if the AC compressor is still on the motor as well. good luck and let me know what bracket fits because I am also trying to retain AC
  7. ksprelude01
    ksprelude01 TK - CivNation
    The AC bracket from a CRV is a cheaper alternative, I forgot which year, but if you order it straight from one of the honda parts companys online you can get it much cheaper than getting the del sol ac bracket. I paid $84 shipped for mine. Maybe that might help. And yes they are the same exact mount.
  8. colombian_jam
    miami
    its the same exact ac bracket from the civic eg because i did the swap just engine not ac compresor i want to kkep the original because i bought like 2 months ago brand new so ur tell me that a crvac bracket will fit mine ac compresor and will work fine
  9. ksprelude01
    the delsol ac bracket and the (years not sure, basicly the ones with the b20 in them) crv ac bracket are the same, have the crv one and its the same size, mounting holes and everything to the delsol one.
  10. NARKOSIS
    NARKOSIS New Member
    i needed the exact same part and yes, the crv bracket is cheaper. I had it sent 3-day and my totaly was $91.99, heres the part number:
    38930-P7J-000
    got it from slhonda.com
  11. colombian_jam
    miami
