new to the carbon fiber game
Discussion in 'Body / Exterior / Interior / Cosmetics' started by civiclxb16, Jul 23, 2005.
  1. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    ok guys just got my first real carbon fiber product it is a VIS carbon fiber hood and i wanted to know what kind of special care do i have to do? wax it? i can use my regular soap to clean it? windex it? let me know
  2. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    I think it should be clear coated or painted. then treat it as though it was a sheet metal peice with paint.
    If it is already cleared. then trreat it as it is paint.
    You could always wet sand it w/ 1200 or 1400 grit paper make it look that much better.
  3. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Usually the ViS products come with a UV protectant coat, my vis cf trunk did, i havent waxed it, but used regular soap on it.
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Never wash anything that has paint/clear coat/resin/ whatever on it with windex.
  5. reikoshea
    Dallas, TX
    What so everytime ive washed my car (painted) i was wrong?
  6. VTECPOWER
    Winchester, VA
    He said with windex.
    Reading > You
  7. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    My dad uses windex to get the bugs off the front of his car. Never had a problem with it, but it's not something I'd do.
  8. Lantis
    Lantis Senior Member
    Fort Worth, TX.
    I use windex on the really tough stains.. and to get the oil and dirt and shit off my hubcaps..
    besides.. why buy carbon fiber? in a few more years carbon carbon will be out and it is like way better than carbon fiber..
  9. civiclxb16
    Poconos pa
    carbon carbon got any links on that?
  10. jdmeg6
    jdmeg6 Senior Member
    So Cal
    Because who wants to wait a few more years to pay more money for something that will look almost the exact same!?!?!
  11. Lantis
    Fort Worth, TX.
    because carbon carbon is the roxxorz..
    and no I don't think there are any links to carbon carbon.. especially since at the moment the only people using it are NASA..
  12. phyregod
    phyregod !!YTINASNI
    Central Texas
    I'm going to go hang out near the Indy dumpsters... They'll be like.. so what if we paid $30,000 for this spoiler! its carbon fiber and that is old shit! Besides, we have 18 of the Carbon Carbon spoilers!
  13. phyregod
    phyregod !!YTINASNI
    Central Texas
    REINFORCED CARBON-CARBON
    RCC fabrication begins with a rayon cloth graphitized and impregnated with a phenolic resin. This impregnated cloth is layed up as a laminate and cured in an autoclave. After being cured, the laminate is pyrolized to convert the resin to carbon. This is then impregnated with furfural alcohol in a vacuum chamber, then cured and pyrolized again to convert the furfural alcohol to carbon. This process is repeated three times until the desired carbon-carbon properties are achieved.
    To provide oxidation resistance for reuse capability, the outer layers of the RCC are converted to silicon carbide. The RCC is packed in a retort with a dry pack material made up of a mixture of alumina, silicon and silicon carbide. The retort is placed in a furnace, and the coating conversion process takes place in argon with a stepped-time-temperature cycle up to 3,200 F. A diffusion reaction occurs between the dry pack and carbon-carbon in which the outer layers of the carbon-carbon are converted to silicon carbide (whitish-gray color) with no thickness increase. It is this silicon-carbide coating that protects the carbon-carbon from oxidation. The silicon-carbide coating develops surface cracks caused by differential thermal expansion mismatch, requiring further oxidation resistance. That is provided by impregnation of a coated RCC part with tetraethyl orthosilicate. The part is then sealed with a glossy overcoat. The RCC laminate is superior to a sandwich design because it is light in weight and rugged; and it promotes internal cross-radiation from the hot stagnation region to cooler areas, thus reducing stagnation temperatures and thermal gradients around the leading edge. The operating range of RCC is from minus 250 F to about 3,000 F. The RCC is highly resistant to fatigue loading that is experienced during ascent and entry.
    They are using it on the nose and leading edges of the wings of the shuttle.. Its heat deflection material.
    ***PS***
    I also read that it "lacks impact resistance"
    This was proven by the 2003 shuttle that blew to bits over texas. A chunk o insulation hit the wing's leading edge (made of carbon-carbon) and broke it.
  14. civiclxb16
    Poconos pa
    wow good stuff dam good write up i guess carbon carbon is going to be a hood in like 2220..lol time for a new topic look out for it...lol
