New toys :)
corvetteguy78
Well-Known Member
VIP
Long time no talk :) Just stopping in to say hi...
Picked up something alil nice for myself...
BIC Acoustics Cinema 6 Home Theater Speakers..I was gonna go with Bose but these blow Bose out of the Ocean
The Acoustech Cinema Series H100 subwoofer fills a room with clean bass that highly enhances music or deep rumbling bass for exciting home theater sound. This subwoofer is a super value. A sleek cabinet with high gloss houses a heavy duty 12" front firing woofer. 500 watts dynamic peak output. Performance guaranteed to knock your socks off especially at it's price..
Woofer - Long-throw 12".
Power - 500 watts dynamic peak output (150 watts RMS continuous).
Max Acoustic Output - 115 dBSPL
Frequency Response - 24 Hz - 200 Hz (+/- 3 dB)
Enclosure - vented
Dimensions - 17" H x 15 W x 18 1/4" D
Crossover Frequency Range - 40 Hz - 150 Hz
Each Acoustech HT-75 tower houses dual 6" woofers combined with a high efficiency horn tweeter or a true theater like experience. Wide dynamic range up to 116 dB output. High gloss tops and bottoms also add to a sleek cosmetic design. The new Acoustech high efficiency Cinema Series delivers performance rich in clarity and guarantees large spectrum theater-like sound.
Design - Video shielded, two-way, three component tower.
Frequency Response - 35 Hz - 20 kHz (+/- 3 dB)
Drivers - Dual 6 1/2" woofers, one 6 1/2" mid/high frequency horn neodymiu magnet
Sensitivity - 96 dB @ 1 watt,1 meter
Power - 10 - 150 watts per channel.
Dimensions - 40" H x 9 W x 8" D Impedance - 8 Ohms
Limited Warranty - 2 years parts & labor
The new Acoustech HT-65 Center is a high efficiency Cinema Series delivering performance rich in clarity and guarantees large spectrum theater-like sound. The center houses dual 6" woofers combined with a high efficiency horn tweeter for a true theater like experience. Wide dynamic range up to 116 dBoutput. High gloss tops and bottoms also add to a sleek cosmetic design.
Design - Video shielded, two-way, three component center.
Frequency Response - 55 Hz -
20 kHz (+/- 3 dB) Drivers - Dual 6 1/2" woofers, one 6 1/2" mid/high frequency horn with neodymium magnet.
Dimensions - 8" H x 22 W x 6" D
Impedance - 8 Ohms
Limited Warranty - 2 years parts and labor.
The new Acoustech HT-63 high efficiency Cinema Series delivers performance rich in clarity and guarantees large spectrum theater-like sound. The HT-63 bookshelf speakers have a unique angled cabinet for wide dispersion of sound. Each unit contains a 6"woofer combined with a high efficiency horn tweeter. A 5" x 7"passive radiator is also utilized. Wide dynamic range up to 116 dB output. High gloss tops and bottoms also add to a sleek cosmetic design.
Design - Two-way, three component bookshelf.
Frequency Response - 60 Hz - 20 kHz (+/- 3 dB)
Drivers -Dual 6 1/2" woofers, one 6 1/2" mid/high frequency horn with neodymium magnet.
Sensitivity - 96 dB @ 1 watt, 1 meter
Dimensions - 14" H x 9 W x 8" D
Impedance - 8 Ohms
Paired up with Onkyo 674s 7.1 700 wat Receiver
THX Surround EX and THX Certified
· Cinema Re-EQ
· Extended Frequency Response (+ 1 dB, - 3 dB) 10 Hz-100 kHz
· DTS, DTS-ES Discrete/Matrix 6.1, DTS Neo:6
· DTS 96/24
· Dolby Digital, Dolby Pro Logic II
· Dolby ProLogic IIx
· Dolby Digital EX
· A-Form Listening Mode Memory
· Multichannel Input 7.1
· CinemaFILTER
· Digital Soundfield Processing Modes
· Late Night Mode
· Adjustable Digital Delay
· Crossover Adjustment
· HDMI 2 Input / 1 Output, 1080p bandwith ready for next generation DVD players
· Auto Speaker Calibration with Audyssey 2EQ Creates an optimal listening area, not a point - perfect for families
· Video Upconversion to HDMI with deinterlacing ensuring your video looks the best on the newest tv's
Specifications:
General
· Channels: 7.1
· THD (Rated Power): 0.08 % (Rated Power)
· Damping Factor (1 kHz, 8 ohm): 60
· Input Sensitivity and Impedance: 200 mV/47 k-ohms
· Output Level and Impedance: 200 mV/470 ohms
· S/N Ratio: 106 dB (Line in, IHF-A)
· Frequency Response: 10 Hz-100 kHz/+ 1 dB, - 3 dB (Direct mode)
· Dimensions (W x H x D): 17-1/8" x 6-7/8" x 14-13/16"
· Weight: 25.1 lbs.
Power Output* (8 ohm, 20 Hz-20 kHz, FTC)
· Front: L/R 95 W/Ch
· Center: 95 W
· Surround L/R : 95 W/Ch
· Surround Back: 95 W
Power Output* (6 ohm, 1 kHz, FTC)
· Front L/R: 115 W/Ch
· Center: 115 W
· Surround L/R : 115 W/Ch
· Surround Back : 115 W/Ch
Dynamic Power** (front)
· 3 ohm 225 W
· 4 ohm 170 W
· 8 ohm 105 W
Tone Controls
· Bass: +/- 10 dB, 50 Hz
· Treble: +/- 10 dB, 20 kHz
Tuner Usable Sensitivity
· FM Mono: 15.2 dBf, 1 uV (75 ohms, IHF)
· FM Stereo: 22.2 dBf, 2 uV (75 ohms, IHF)
· AM: 300 uV/m
Tuner S/N Ratio
· FM Mono: 73 dB (IHF-A)
· FM Stereo: 67 dB (IHF-A)
· AM: 40 dB
THD:
· FM Mono: 0.3 %, 1 kHz
· FM Stereo : 0.5 %, 1 kHz
· AM: 0.7 %
Very nice man. One of my instructors at ITT was looking to build a setup alot like that. How much did that run you? Looks good, are you gonna take the time and get the acoustics down in your entertainment room?
The speakers were $799 from sounddistributors.com and the reciever was $399 from ecost. Its all being setup in the living room :)
Saweet. I generally don't buy into the Bose hype - there are usually better systems out there with greater value per dollar. I have a friend who has an 8 year old Macintosh Audio setup going through a 5 year old Onkyo reciever and it sounds way better than a higher-priced modern Bose 3 speaker setup.
bose sucks. you did yourself a favor.
oh, and come to my house warming. sat oct 13th
pm me for directions
Not trying to open an old tread but why does Bose suck? I don't have much experience with stero systems but I always heard it was good stuff.
Bose don't suck....they are good speaks but for the price there are better speaker systems out there....you can't deny the sound quality that comes out those little speakers.....
When I bought my speakers from Soundistrubutors.com I called and the guy told me if i didn't like these better then the Bose system then he would pay to have them shipped back so i had nothing to loose, i already knew what bose sounded like and obviously the story ends with me keeping these speakers :)
For me personally I like Floor Standing Speakers with big center channles and surrond sound...
enough said
congrats on your new purchase man. We arent too picky yet since we still live in a mobile home but i plan on getting goo setup when we buy a house....
and i plan on getting one of the Fathon's
i know, i know. :lol:
it just funny how i was just looking at these and saw this post. I see the money flow has been improving huh
Taco...this was my post from 2007 hehe, someone brought it up recently....was just responding :p
vette guy is right. i heard my friends little alarm clock sized radio from bose and i was suprised at how much bass and clarity it put out.
then i heard how much he paid for it and was like,"psshh" :rolleyes:
But if you want a serious sounding system you can always go woth Wisdom Audio's "Infinite Wisdom Grande" system for $700,000 which the entire system weighst more tehn my car at 3800lbs
Specifications:
Drivers (Planar Array Line Source)Six 75"x3" Planar Magnetic/ChannelDrivers (Low Frequency Regenerator)Twelve 12" Underhung 3" coilLine Source Driver Weight258 lbs. each channelLow Frequency Magnet Weight456 lbs. each channelFrequency Response10-25,000 HzHorizontal DispersionOver 130 degreesVertical Dispersion12' Line SourceSensitivity 1W/1M Equivalent91dB Equivalent RatioLine Source (Nominal Impedance)5.5 ohmsLine Source (Minimum Impedance)5.5 ohmsLow Frequency Regenerator ImpedanceChoice of 2, 4 or 6 ohmsActive Crossover Point (Planar Array and Woofers)100 HzActive Crossover Point (Planar Array and Woofers)600 HzPassive ComponentsNoneRequired Channels of Amplification12 (14 to 20 as an option)Max. Power Handling (Planar Array Line Source)6000 watts per channelMax. Power Handling (Low Frequency Regenerator)12000 watts per channelRecommended Amplifier Power (Planar Array Line Source)200-750 watts per channel (x4)Recommended Amplifier Power (Low Frequency Regenerator)600-6000 watts per channelComplete System Weight3800 lbs.Line Source Cabinet (H" x W" x D")160" x 21" x 60"Low Frequency Cabinet (H" x W" x D")102" x 32" x 48"
I like Bose i have Bose Companion III computer speakers and the things are as loud as anything and the subwoofer is insanley bassy
too big. :(
i would much rather build my own from high end car audio high and mids. I have one of my audio friends who did that and ilooks and sound good.
i like my cheapo samsung that i bought from best buy.
too big. :(
I have a Samsung surrond system in my bedroom that i got from best buy....its the HT-TZ312 model
