Say if i had an engine swap and had the ecu reworked to match up with the engine. The engine becomes no good and its time to swap it out for a rebuilt or new one, will I have to make any changes with the ECU???
I'm pretty sure no one understands your question. Please reformat it and make it clear as to what you want to know. Be specific like what engine and what ECU.
????????? do they speak english is what!!!, say it again, i dare you!!!! I double dare you mother f***ker!!
J/K
yeah......a little more info would help.......hehehehe
you have a rechipped ECU for an engine you swapped in???
the engine is shot so your swapping in another one???
now you want to know if the ECU you have will work with the next engine???
if this is the case we need to know what engine you had ... what ECU you were running it with... and what engine you plan to put in now....
