Newbie needing help with ls/vtec!!!!
Discussion in 'HYBRID -> EG-EK / DC' started by JOSE DC2, Jan 23, 2010.
  1. JOSE DC2
    JOSE DC2 New Member
    Could anyone help me with my ls/vtec motor build.
    here is my setup let me know if i need anything more!
    b18c1 head /ported & polished
    CTR-cams & cam gears
    CTR pistons
    Injen cold air intake
    buddyclub catback exhaust
    goldel eagle vtec conversion kit
    ARP studs & rod bolts
    p30 ecu
    GSR timing belt
    ITR water pump & oil pump
    adjustable fuel pressure regulator
    310cc injectors
    thats what i'm building so let me know if you guys have any suggestion i expect to make around 200-235 hp
  2. 99sidude
    Ohio
    Which intake manifold are you going to use? The stock gsr isn't all that great for ambitious projects such as yours.
  3. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    sounds like a good solid build. i think 200whp will be a good goal for it. to get north of 220 you need more compression and bigger cams for sure.
    also how are you planning to tune it?
