newbie
Discussion in 'HYBRID -> EG-EK / DC' started by xxx92vtechatchxxx, Apr 5, 2006.
  1. xxx92vtechatchxxx
    xxx92vtechatchxxx Junior Member
    well im new to hondas just bought my first honda a 1992 civic hatchback with no motor or trans so i get to start from scratch. ive been looking at puting in a gsr swap . ive been doing alot of homework and i got alot of stuff down. i know you supposed to change the shifter linkage which the guy left on the car, axles, wire up the vtech, buy mounts from hasport and do something with the obd2. Im going to take it apart and put low comp pistons, sleeve the block and do all forge internals. as you can tell im going to run a custom turbo setup. my question is do i have to worry about the obd1 and obd2 if im going to run a ems? the vehicle is not a going to be a daily driver. i hope to get 500 to the wheels. and as far as the swap am i missing anything? do i have to get a obd1 motor or obd2? thanks in advance [​IMG]
  2. 97hatch
    97hatch ?
    Anderson IN
    obd does not really matter
    o would tink about some thing diffrent than a gsr because the intake manifold is diffrent then the rest of the b series and you also have the sec butterflies to mess with also if you are truely building it up maby a properly built ls vtec
  3. xxx92vtechatchxxx
    well i wasnt planing on using the stock intake im gonna do a aftermarket
  4. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    If you're going to build it, build an LSVTEC.
    Keep it obd1, you will be happier.
    Use the shift linkage from 94-01 integra.
  5. TeinGirl
    TeinGirl Senior Member
    DFW, Texas
    LS 4 th3 w!n...
    and :werd: on the obd1
  6. 97hatch
    97hatch ?
    Anderson IN
    exactly if you plan on changing the manifold you have very few choices with a gsr because the bolt patern is diffrent than a b16 and a b18c5
  7. xxx92vtechatchxxx
    well hell i didnt know the bolt pattern was differnt well ill look into it somemore. do i stick with the trans that comes with the swap?
  8. 97hatch
    97hatch ?
    Anderson IN
