next mod??
Discussion in 'Engine Building' started by robtec, Oct 28, 2003.
  1. robtec
    robtec Junior Member
    2000gsr
    skunk 2 im
    iceman intake
    dc 4-1 header and catback with no cat
    fpr set at 44psi
    ignition timing at 18 degrees
    best et.14.7 best mph. 94.9
    i was thinking ,skunk stage 1 cams and vafc,what do you all think??
  2. pissedoffsol
    put your fuel pressure back to stock. you don't need it.
    put your ignition back to 16 bdc, you don't need it.
    those would be my next 2 mods.
  3. DesertNightEagle
    DesertNightEagle Senior Member
    Perryville, MD
    i think you should take off the head and get it ported. and if your doing that you might as well buy the cams for it since you'll have the head apart
