NGK Spark Plugs Available At CorSport
Discussion in 'CorSport' started by CorSport, Sep 9, 2011.
  1. CorSport
    CorSport Member
    NGK Spark Plugs
    [​IMG] [​IMG][​IMG]
    NGK Spark Plugs
    Click here to see this product in our catalog and check out the most current pricing.
    The Spark Plug
    Serious Enthusiasts Rely On
    Designed specifically for the performance enthusiast. Iridium IX® offers extreme ignitability, improved throttle response and superior anti fouling
    Fine Iridium tip ensures high durability and a consistently stable spark
    Iridium alloy has extremely high melting point, perfect for today’s high-tech, high-performance engines
    Trivalent Metal Plating - superior anti-corrosion and anti-seizing properties
    Outstanding acceleration, high fuel efficiency and durability
    Ultimate design, technology and performance.
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  2. CorSport
    CorSport Member
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    NGK has my endorsement. I have NEVER had one fail me. Ever.
  4. CorSport
    CorSport Member
    True story. No other plugs go in our engines
  5. CorSport
    CorSport Member
    1992-2001 Acura Integra GSR Laser Iridium Spark Plugs (4) OEM Replacement B18C5
    [IFR6E11] $68.00
    CorSport: NGK - IFR6E11
  6. CorSport
    CorSport Member
    Bump! Get your car tuned up for winter time.
  7. CorSport
    CorSport Member
    NGK spark plugs ready to ship!
    :thumbsup:
  8. CorSport
    CorSport Member
    Get more spark in your life with NGK!
  9. CorSport
    CorSport Member
    96-00 Honda Civic NGK Wire Sets
    [​IMG][​IMG][​IMG]
    Our Spark Plug Wire Sets are built to meet stringent OEM tolerances for a variety of import vehicles *
    Superior Firing and Fuel Savings
    Outstanding Durability
    Consistent Performance
    Excellent Noise Suppression
    Perfect Fit for Your Car
    When a spark plug fires, it creates a great deal of radio frequency interference (RFI) and electromagnetic interference (EMI). Uncontrolled, this can show up as static in the radio or other electronic devices, or much more seriously, in electronic ignitions, fuel injection, and engine management systems. This interference with EFI and engine management systems can cause "cross talk" between wiring harnesses resulting in poor running, misfiring and decreased performance.
    NGK Resistor Spark Plug Wire Sets utilize a construction method known as "variable pitch" wire winding to create resistance to radio frequency interference. The variable pitch winding (loose/tight/loose) provides suppression throughout a very wide range by "scrambling" and breaking up the electrical waves radiated by the firing of the spark plugs.
    CONSTRUCTION
    A ferrite magnetic layer consisting of a mixture of rubber, plastic and powdered ferrite magnetic materials, offers uniform resistance and unsurpassed conductivity. NGK wires have a lower resistance than conventional carbon core wires (8k ohm/meter vs. 16k ohm/meter). This comparison is important to remember when you consider that many manufacturers recommend wires be replaced when the resistance exceeds 20k ohm/meter. This does not leave much margin for wear when the wire may only meet original standards at the very early stages of its life.
    At the center of NGK Resistor Spark Plug Wire Sets is a fiberglass stranded core, made from the same family of materials used in bullet proof vests. This core greatly enhances the overall strength of the wire, providing a super strength backbone on which the various layers of the wire assembly are formed. The core gives protection from damage caused by the pulling strains that wires are often subjected to and that can destroy their performance. *
    High quality EPDM and Silicone coverings are used to resist high heat, oil and chemical damage for increased durability. *
    Custom designed terminal boots are always used to provide exact fit (not universal fit like other major wire manufacturers). Each NGK ignition wire is fitted with a positive locking, corrosion resistant Stainless Steel terminal end for tight fit and maximum resistance to vibration and separation.
    NGK Wire Sets are numbered for easy cylinder identification and coil wires are color coded for correct and easy installation.
    CorSport USA.
  10. CorSport
    CorSport Member
    Plugs from NGK for more spark in your life!
  11. CorSport
    CorSport Member
    NGK Laser Iridium Spark Plugs (4) OEM K24A2 Replacement
    [​IMG][​IMG][​IMG]
    Laser Iridium spark plugs provide superior ignitability and long service life. Smallest tip diameter available Iridium / Platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions.
    stock # 6994
    Laser welded Iridium center electrode tip
    Platinum disc welded to backside of ground electrode provides long service life
    “Trivalent Metal Plating” provides superior anti-corrosion and anti-seizing properties
    Faster starts and quicker acceleration
    Better fuel economy and lower emissions
    Best OEM Iridium spark plug available
    Original Equipment Manufacturer approved design
    ***Shipping is included
    CorSport USA.
