NH 95 Civic Coupe w/ LS swap and other goodies
UNDR8D
...has a job!
The car is pictured here in this thread:
https://hondaswap.com/hybrid-eg-ek-dc/my-ls-swapped-ej2-w-pics-115683/
It has all new parts including:
JDM ls, s80 transmission, timing belt, water pump, clutch, flywheel, axles, wheel bearings, rotors (drilled and slotted front, oem rear), ceramic pads, new lifetime warranty struts, cheap Ractive coilovers, Honda shift linkage, short shifter, Sunpro tach, OEM Integra radiator, new radiator hoses, new distributor, new starter, all tune-up parts (including plugs, wires, cap, rotor etc.), larger 15/16" Integra master cylinder, Integra rear disc swap, new battery (relocated to trunk), reprogrammed ecu, new tires, Honda oem mirror block off, oem antenna block off, roof rack, 1 piece header, hand fabricated exhaust, hand fabbed intake, relocated coolant overflow, and more.
It is a solid reliable car. It has a couple small rust spots and blows a little smoke on occasion. Also, the interior has no carpet and no side panels in the rear. It would make a great daily driver or a great parts car.
Car is in Southern NH. $2500 OBO. I am moving to California and can't take it with me. Also, if you try to steal it I will shoot holes in your face. I live in the woods and own shotguns. Thanks for looking!
