nitrious
Status
Not open for further replies.
is useing nitrious and a turbo on the same car a good idea cuse i have a del sol and i want to do both..
If your motor is built or you plan on using a small amount of each. But then that would be a waste because you can get a small turbo and get almost instant boost without the nitrous or you can just run nitrous and not have to spend at least 1000 on a turbo system.
Most people run both because: 1)They have built motors that can handle such abuse. 2)They need both because they usually have a huge turbo that needs nitrous to spool it faster.
This topic has been closed :locked:
Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth.
If you have any questions, please PM the moderator who closed this topic.
-The moderating Team
Status
