nitrous and timing
Discussion in 'Forced Induction' started by mozzandherb, Jun 22, 2005.
  1. mozzandherb
    mozzandherb Senior Member
    I have a question. It is recommended that if you go with Nitrous (75 shot) that you should retard your timing by 2-4 deg. Does this mean that you should only retard the timing when your using Nitrous like when you go to the track? Is it O.K to have the timing delayed when your not using the Nitrous and your just driving around town.
  2. pissedoffsol
    its ok, but you'll be slower and get a little less MPG.
    2 should be MORE than enough for a 75 shot.
