Nitrous?
Discussion in 'General Tech and Maintenance' started by sub95, Apr 15, 2003.
  1. sub95
    sub95 Junior Member
    Cali
    have a 90 crxhf with a stock b16 with all the bolt ons's,
    looking into 55-75hp nitrous kits, what one would be the best one to get? and what extra's should i get to make it as safe as can be for the motor?
    thanks
  2. pissedoffsol
    zex or Nitrous express are probably the best kits.
    unless you can afford a venom kit- which most people can't.
    get a couple degree colder plugs, and perhaps a fuel pressure regulator to up the psi a notch or 2, but not much more
  3. WarMachine
    WarMachine Junior Member
    NOS direct port efi nitro kit comes with fuel safty switch,window switch,and cheater fuel solenoid.No mods needed to install. It's a littie pricey around $1000. for complete kit. :D
  4. EGLSHB
    EGLSHB Senior Member
    my little brother has a 90 si, w/b16 set up about like yours, and he has run a zex kit for over a year, and hasn't hurt anything... and he drives the piss out of that little car.. best time (55 shot) 13.8 in the 1/4, and the HF weighs 200 pounds less, so ....
  5. sub95
    sub95 Junior Member
    Cali
    cool, Thanks alot.
