NO AC!!!!
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Blk_95_lude, May 18, 2005.
  1. Blk_95_lude
    Blk_95_lude Junior Member
    recently i found out that my ac wasn't connect, i plugged it in only to find out that there is no power in that wire. The compressor is fine because i jumped it from the battery and it kicked on. I tried to follow where the wire goes but its a bitch because it blends into the harness really good. I was just going to run my own wire with a switch but i'd rather find out what the problem is first. Thanks
  2. reikoshea
    Dallas, TX
    is there a fuse/relay for the AC...might wanna check that.
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    :werd:
    Check your fuses. Then, trace the wire back as far as you can, and observe the color of the wire. There has to be a relay for that wire. You should only have to replace the wire before the relay or after it. If your switch is working properly, you should have continuity between the terminals when depressed.
