No cat
Discussion in 'General Tech and Maintenance' started by 2fastaccord, Sep 29, 2003.
  1. 2fastaccord
    2fastaccord Senior Member
    Will not having a cat create a lot of road noise from beneath the car toward the rear?
  2. 2fastaccord
    I remember reading a thread recently and one of you guys said that the only noise in your car came from having no cat. It was that thread about sound dampening like dynomax and stuff like that. Any help would be greatly appreciated. I am tired of hearing all this road noise in the hatch of my rex.
    Peace*
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I had a testpipe and it make no noise at all with the cat off.
  4. SLA
    SLA Senior Member
    Rochester, NY
    Having no cat will raise the nosie level because one of the functions of a cat is to lower the noise!
  5. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Exactly. The cat acts as sort of a muffler within the exhaust system.
  6. wildbillhatchbac
    wildbillhatchbac the OG VIP
    its hard to beleive that the noise you are hearing is from not having a cat.
    how about tire noise? bad wheel bearing maybe.
    did you do anything to your car before you noticed the noise?
  7. kyleirwin
    kyleirwin Retired OG
    Vegas
    i think it's one of those damn exhaust bearings causing all that racket.
  8. Dman1100
    Dman1100 Senior Member
    Des Moines IA
    on the topic of exhaust, dumb question. Whats that canister between the cat and muffler right behind the shifter?
  9. tab
    tab Super Moderator
    Aberdeen, Washington State
    :lmao:
  10. h22a_in_a_si
    h22a_in_a_si Junior Member
    You guyz are all trippin. I took my cat off a week or 2 ago, and it sounds the exact same. I heard it only farts if you have a straigt pipe, or a straight through muffler. Pop that shit off!
  11. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    It makes a sound, but barely any. It sounds almost like a short ram intake. It helps a lot with high end power. The noise you hear is 99% something else, check with what everyone else here said, sounds right.
  12. dok
    dok Senior Member
    I second I took my cat of the noise went all over the place but more tor as well you give little to get alot
  13. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    its the resonator
  14. seanjuan
    seanjuan Senior Member
    Twin Cities, MN
    IMO the cat doesn't lower the sound very much and most of the time when people take the cat off it's because they are redoing the whole exhaust and then they blame the added volume to having no cat and not to the new catback system they just put in. The resonator is also supposed to quiet the system and I recently cut mine out and replaced it with flex pipe (it pretty much rusted off one day) and I couldn't tell a difference in volume (still very quiet and nearly stock sounding)
    You could try puting you cat back in and seeing if that gets rid of the sound, otherwise maybe try some sort of sound proofing stuff
  15. JDMilan
    Boca Raton, FL
    the cat doesn't act as a noise resonator,,that is what the resonator in the exhaust system if for, the cat is an emissions issue to protec the environment.
    I had a ITR 4-1 with a 2.5 collector, test pipe and Apex WS and it was quiet, very low key.
  16. dragoon118
    dragoon118 Member
    California
    i have dc 4-1 headers 2.5 collector and a punched out cat connect to a rs*r exhaust and its very quiet. i didn't notice any difference between the stock cat and the punched out one. both sounded the same to me.
