No Clutch Pressure
Discussion in 'Prelude' started by Dachdu 92, Aug 22, 2010.
  1. Dachdu 92
    Dachdu 92 New Member
    Hey everyone, I'm Thinking about buying a 3rd gen Prelude SI that was parked because it was sideswiped, and i went to fire it up and the clutch had no pressure, what does this mean? I doubt the clutch is broke because it is obvious it was parked because of the wreck (door doesnt close all the way). Does anyone know how to fix this?
  2. Briansol
    probably the salve cyl on the tranny. they go, are fairly cheap and easy to replace. check the clutch fluid though, you may just need to top it off in the clutch master and pump it up a few times
  3. Dachdu 92
    ok ill have to try that, i also forgot to mention the clutch stayed on the floor will that solve this too?
  4. vpower
    vpower New Member
    L.A.
    is it cable or hydro tranny???if it is a cable tranny it is possible the cable snapped which is an easy fix also...
  5. Dachdu 92
    Im not sure its an 88 though so maybe cable?
  6. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    Should be a cable tranny for that year. Check the cable and see if it broke or came disconnected at tranny or clutch pedal.
  7. eg6sir
    could be the slave cylinder as B said, or the master cylinder
