no cooling system pressure...help?
Discussion in 'HYBRID -> ED-EF / DA' started by EFDX, Aug 25, 2010.
  1. EFDX
    EFDX New Member
    90 si with b18a1 newly installed, new rad, new rad cap, new heater core, new w/pump, new t/belt, new t-stat, no external leaks, no milky oil, no white smoke out the pipe!! HELP!!!!!!!
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Air in the system? Did you bleeding the cooling system?
  3. EFDX
    EFDX New Member
    yeah i did everything propper like, got is sorted, turns out it needed to be loaded up to get that extra bit of heat into it, 20 min idle wasn't enough
