no fuel pump and car wont crank
Discussion in 'ECU's, Electronics, and Tuning' started by vjace, Aug 30, 2006.
  1. vjace
    vjace Junior Member
    ok this is my very first swap i did everything on the car its a 96 civic ex obd2
    i put an obd1 b16. p 30 ecu with the conversion harness. i almost finished the car. i just need to put the radiator in and axels and the o2 sensors too call it a day. my problem is when i went to crank it i didnt. i didnt hear the the fuel pump and it didnt even crank im guessing a ground somewhere? i dont have a battery but i hooked it up to a tricker so maybe thats why it didnt work but i cant see why cuz everything eles worked. radio and so on. i also didnt hook up the ground strap that goes from the engine too the body but i didnt think that makes a diff cuz i took that off my car integra and it still started up. ugg so confuesed any help would be great thanx
  2. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    You need the grounds on, thermostat and transmission grounds.
  3. vjace
    vjace Junior Member
    i know the one on the thermostat is on but the one on the transmission were would that be located? i dont remember having a ground on their is it like a plug cuz i think i might hace like 2 plugs on their i dont remember i pluged everything up and then droped the motor in.
  4. Crack
    Crack Junior Member
    Check your main relay, worked on a car that done the same thing,and thats what is was.
  5. reikoshea
    Dallas, TX
    if it was the main relay, the car would at least crank. i second checking all grounds.
  6. Crack
    Crack Junior Member
    The car will turn over it just wont get fuel or fire so it could be that , just saying ya know
  7. reikoshea
    Dallas, TX
    I dont know about you, but to me that means it didnt even turn over, aka, not the main relay, but a ground is possible.
  8. VTECin5th
    Phoenix Az
    The transmission ground is the thick ground wire in the transmission mount area.
    It's hard to miss unless you didn't have one there.
    My single cam's transmission ground fell off, it turned over fine, then one day it quit. I regrounded it and it was fine.
  9. vjace
    vjace Junior Member
    it wasnt their i put that their i have fuel now yahoo.
    but now i have no power going to the starter? what fues that would be?
    and my car makes alot of clicking noises when i try to start it comes from behind the glove box? i would have to play with the ignition switch on and off till it goes of or to make the fuel pump to kick on? once it kicks on the clicking goes away. but thanx for your help guys!!! any help with the starter would be great
  10. reikoshea
    Dallas, TX
    sounds like a missing ground
  11. vjace
    vjace Junior Member
    for the starter? were how? i looked high and low and the only conclusion i come up with it that the starter doesnt have power going to it. and im thinking its the starter relay. how do i check a relay? any help would be great thanx.
  12. VTECin5th
    Phoenix Az
    Can you push start it?
  13. vjace
    vjace Junior Member
    havent tried yet im ganna once the axels r in.
