No injector pulse 96 ej8 with swap b16a2
namoper
Ok I have done the above swap. The car is obd2a I have got the conversion harness and converted it back to obd1. Running a p28 ecu.
Car will not start.
Its not getting a pulse at the injectors. I can spray wd40 into the intake and it will run as long as I do this so I know the motor is fine and has spark.
I have checked voltage at injectors. 12v.
Resistance is 11.9 on all 4.
Grounds are all good.
Does anyone have any idea what else to check. Its not giving any cel codes so I am at a loss here.
Thanks.
