no interior lights
Discussion in 'Car Audio / Security / Electronic Accessories' started by 92integralsvtec, May 24, 2008.
  1. 92integralsvtec
    92integralsvtec New Member
    ok no idea what i did but when i got the car it all worked perfectly fine. i put in a new deck n now it dont work, i triple checked my connections and they are all right. i checked for a blown fuse, no luck. what could have cause all my interio lights, except dash to not work and when i push the button for the lights it resets the clock in the dash and no lights on the cluster or anything work?
    im thinking mayb it has something to do with the tac that was in it, i pulled it out cause it had a stock one but all i did was undo the connections cause they were just twisted and made sure they were cut so they wouldnt touch nothing. could something in that be my problem?
  2. neonmike
    neonmike Senior Member VIP
    sounds like you shorted out a wire and blew the dimmer switch
  3. 92integralsvtec
    is there a way to test if its my dimmer or not and how much roughly would it be?
  4. ricco
    ricco New Member
    Oem radio has dome & security wired thru it. Back of it has a green security plug that .just be plugged in to keep these functions
