no lights
Discussion in 'ECU's, Electronics, and Tuning' started by etccatz, Aug 26, 2007.
  1. etccatz
    etccatz Junior Member
    alright i have had nothing but problems with this car but its a car that i wanted for ever so i put up with it. i bought a 88 crx dx manuel finally got it running and now the reverse lights dont work. i changed the bulbs and switch the reverse switch with a used switch that worked but the lights still dont work?? can anyone help me with this problem because it wont pass inspection until i fix this???? thank you.
  2. Kyle21nluvnit
    Kyle21nluvnit New Member
    Do you have a wiring diagram? Do you know how to use a DMM(digital multi-meter) if you are comfortable doing elec. diag. ten let me know and I will walk you through the diag for this proble.
