No more check engine light..buuuut
Discussion in 'Accord' started by 90AccordCDN, Sep 24, 2007.
  1. 90AccordCDN
    90AccordCDN New Member
    Ontario Canada
    So I was having problems with my car, the flexpipe was all mangled so I needed to replace it.
    I take it into Midas (big mistake) for an estimate, which I guess to them means they try to fix it and they break my O2 Sensor :p
    Anyway I buy the parts off ebay (i know, i know don't say it) and I get a deal on headers too. Turned out to be A LOT cheaper then having the shop do it.
    So I install everything myself and the car runs great! No engine lights or anything.
    Problem is, the gasket I received is useless (the one from the header to the pipe), I burnt it out in 2 days and now the car sounds really throaty. I have used silicon but the problem persists after a day or so.
    Anyone know a way around this? If I wanted my car to make unnecessary noise I would have put a fart cannon on it. ^_^
  2. cbr2car
    cbr2car New Member
    in that situation id try using exhaust paste on the sealing surfaces, but if there is too much of a gap and vibes that wont last long.
    you can also cut up an exhaust bandage into a gasket shape and use that and exhaust paste, or try some high temperature silicone.
    hth
  3. heartagram85
    heartagram85 New Member
    Waterford,Michigan
    use a quality gasket....and make sure you torque the bolts correctly
    Also start it up so the gaskets can warm up then re-torque the bolts
    Then the gasket will seat properly
  4. 90AccordCDN
    Ontario Canada
    Yeah I took it into a shop and they gooped it up, that didnt last long either. Went and bought a good gasket, just need the exhaust goo. And with any luck the exhaust wont rattle anymore either.
