No Power To Coil!
lovinhonda
Ok, I bought a 98 USD Integra Type R that had been rear-ended. When I bought the car there was no battery in it. Anyways, the car won't start. The problem is that there is no power getting to the coil. However, there is power at the Ignition switch.
Originally, I thought that it had something to do with the aftermarket alarm system, so I basically un-installed it...No Luck.
The car turns over, and Im sure that no spark is the only problem. (checked with timing light)
Any assistance on this issue would be much appreciated.
