hello to all. this is my first ever post on a forum. i had a 98 civic hatch, and swaped in a b18c engine and trans out of an acura right from japan. pcm from that car also. modified a wiring harness. all was well until the car got t-boned and totaled car. engine still ran as normal. impact was behind drivers door. purchased a running, driving, 98 civic 2dr sedan, swapped just like the hatch, and now have no power to fuel pump. just to see if engine would run, i jumped power to pump, and the engine is running on the two outer cylinders. 2 & 3 dont fire. i have spark though. i have not had time to check power at injectors yet. i unplugged one injector at a time and 2 & 3 cylinders did not make a differance. is there an interfacing problem with the body harness?? where do i go with this?
thanx
eric
thanx
eric
