no spark after compression test
chrisdoug
I was going to trade my car and the guy wanted to do a compression test on it I said ok and I watched him do it one plug at a time after that car wont start its not getting any spark
any help?
did the wires fry it? cause they were just layin on the motor still hooked up the the cap, Im a retard and let him do this FUCK!!
or are the wires securely attached. i know it sounds silly, but when you pull the plugs sometimes you can pull the wires loose.
recheck if the dizzy is plugged in..then make sure he put the spark plugs back in..then make sure the wires are tight on the cap and the plugs...next try to reset your ecu..and if that doesnt work then sound like ur dizzy is fucked..but you can also try your main relay
