no spark at the plugs??? what else can i try?
Discussion in 'Civic and CRX - EF' started by socal91REX, Jun 8, 2010.
  1. socal91REX
    socal91REX New Member
    i have a 91 crx stock 1.5 base model, my car WAS having trouble idleing, stalling, if i gassed it hard, it would almost die out stuttering ... finally it stopped running when i was on the freeway. i replaced the plug wires and plugs cap rotor and distributor and checked all the fuses twice. the ecu is giving me one flash, i didnt check it the same day it broke down if that matters. from what iv read it could be the MAIN RELAY. if anyone has any ideas
    holler at me thanks :confused:
  2. oscar E
    oscar E New Member
    check ur timing i had that same problem
  3. socal91REX
    so if timing is off it wont spark. ill check that today. if i had a bad O2 sensor or map sensor would that also cause no spark.
  4. 8secHonda
    8secHonda New Member
    those wouldnt cause it not to spark (to my knowledge), timing being off it should still spark but not at the right time... did u change the main relay u asked about?
  5. Briansol
    a bad map or o2, the car would still run, but like crap.
    if wired wrong, who knows what may happen.
    you may have fried the ecu itself.
  6. Hfiend
    Hfiend New Member
    boston
    check the relay
  7. socal91REX
    i pulled the main relay and im waiting for the replacement i should get tonight, looking at the old one, it does look like it might have a bad solder point or two. and about the bad ecu, would i get one flash if it was bad??? cause i get one flash.
    thanks for your help
  8. SwapShopRacing
    SwapShopRacing Member
    650n Barranca ave #a Covina, Ca 91723 (626) 261-4
    Code 1 is your O2 sensor, that could cause the car to run rich but has no effect on your spark. Honda ECU Trouble Codes
    Also the main relay is for your fuel pump and should not effect your spark either. Generally getting spark from your distributor is one of a few things. Your distributor it's self including the coil, igniter, etc. could be either or all of the above. Bad plug wires, or bad ECU. Most likely however the problem is in your distributor. How are you checking for spark?
  9. viper4754
    viper4754 Junior Member
    easton
    how do youknow it has no spark did you check it or just asume that check main ecu fuse
  10. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    does it crank? if so check your t-belt
  11. socal91REX
    i checked the spark several differnt ways , so i know the plug was grounded when i cranked it. i also took off the distributor cap to make sure the rotor was spinning. the wiring in the car isnt holding up well. im begging to think i need to replace the whole wiring harness, everthing is so brittle its no suprise im having electrical problems. Its funny really, the car couldnt have broke down at a worse time, my house burned down on the second, and my car breaks down two.
  12. socal91REX
    i checked the ecu again and it gave me one flash, then i think 19 or 20 quick flashes the book doesnt really tell u how to fix either of those so i could use some help
  13. EF9_boy
    EF9_boy New Member
    TX
    i would be willing to bet a punch in the face that it is the ICM (Ignition Control Module)
  14. socal91REX
    that was the first thing i did, then i changed the whole distributor
  15. EF9_boy
    EF9_boy New Member
    TX
    thats weird man my car did the exact same thing i mean the EXACT same thing and it was my ICM
  16. socal91REX
    yeah, it sounded like that was it to me too... i know for sure it has to be flash code 19 "lock up control solennoid valve" now this could cause no spark, im finding it hard to get much info so far... gonna keep looking
  17. socal91REX
    i now kno i am for sure getting power to the dizzy, but no spark..........
  18. socal91REX
    turns out the first thing i changed the distributor was the problem. autozone gave me a bad part, swaped it out, car fired up.... thanks for nothing CHUMPS
  19. alex dx
    alex dx New Member
    take the cover off from the timing check if it moves, if it doesn't move its ur timing or maybe it just jumped a gear. add some fuel on first cylinder if it works its ur fuel if it doesn't no spark
