No spark, not dizzy, not ground
Discussion in 'HYBRID -> EG-EK / DC' started by idgeek, Aug 21, 2005.
  1. idgeek
    idgeek Junior Member
    I've done a B16a2 swap on my '92 cX.
    It started several times and I drove it to the shop for some welding job.
    Now the car does not start. there is no spark
    The shop tried a good dizzy, but still no spark. I replace the coil, still no spark.
    I checked the grounds over and over, everything is good.
    The car turns fine, but will not start.
    One thing I noticed was that the Tachometer dosen't work after the swap.
    Another thing, O2 sensor is not connected yet, but I don't think this has to do with no spark issue.
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    I assume you checked all of the fuses? Might have fried the computer.. It happens on occasion. Try swapping another ecu if you have one handy.
  3. idgeek
    Yes, I've tried 3 ecus, matter of fact. Nothing.
    I know the ECU fuse is good. I'll check the other fuses as well.
  4. triniDEMON
    triniDEMON Member
    CHECK 4 INJECTOR PULSE........AND GROUNDS
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    check the main relay and also check the underhood fuses. Did the disco the battery when weldind on the car?
  6. pissedoffsol
    yeah, sounds like something got fried when they welded... didn't ground properly.
