CharlieP216
Hello, obviously I'm new, but was told this forum is damn good on swap info so hopefully you guys can help.
Alright I got everything straightended out so far except one thing. I have a 2000 Civic using a 99 EX M/T wire harness, have a 97 Del Sol DOHC motor and ecu, and using a OBD2 > OBD1 conversion harness. It doesn't get spark and a friend and I confirmed no spark coming off the distributor (using a dis out of a 2000 Si). Any ideas?
So here's my question, do I need to use the OBD1 dis or can I use the OBD2 one? If I need to use the OBD1 how do I wire it up? Is it much different?
Any help is much appreciated....
