lilboostedcrx
wsup every1 having a lil problem here what i have is a 91 hf crx block with a 89 si crx head i have the motor in the car and all wires/hoses hooked up the problem is that the motor cranks like its about to start but it won't start i pulled the spark plug wire off and no spark so den i changed out rotor, disrtb, coil, wires and still the motor don't start just cranks i checked to see if there was power from the positive and negitive to the coil and there is power i check the outer distrbutor connecters and theres power there so i duno wats wrong with the car my friend told me it could be my ground so if it is can anyone help me to find out exactly which ground needs to be grounded and if its not the ground then wat is it??? i am using a 89 si crx distrb and ecu... sorry ive also posted this on the ecu/eletronics forum cause i wasn't sure exactly where to post this question
