no spark
Discussion in 'ECU's, Electronics, and Tuning' started by B16Ablacky, Dec 19, 2006.
  1. B16Ablacky
    B16Ablacky honkey tits
    hey guys, i just got finished dropping a jdm b16a into my usdm 91 integra. everything is ired up and everything is hooked up mechanically. heres my problem...my engine will turn over but there is no spark. i dont think it is the plugs because i checked for spark with a tester and there was no spark, also when i pulled the spark plug out it and it was a little wet. i tasted the liquid and it did not taste like fuel. i got the engine from hmotorsonline so i do not know how they got wet and like i said i used a spark tester and there was no spark. wat could be causing me to be getting no spark? any help is much appriciated. thank you
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it could be a bad dizzy
  3. turb2o_vtec
    turb2o_vtec New Member
    ^^^ Yeap, dizzy. If not, check main relay.
