NO START 90 accord motor swap
Discussion in 'HYBRID -> BA-BB /CA-CD' started by FTPRACING, Mar 8, 2005.
  1. FTPRACING
    FTPRACING Member
    1990 accord lx 5spd f23 swap 25K
    p28 ecu burned
    Motor has fuel rail with 440cc on resister, runs on 94 oct
    Problem car does not start, turns over and over, does not sound like its firing
    it does have spark and is getting fuel, timing should be right
    new parts:
    fpr
    fuel lines
    main relay
    rail
    injectors
    resistor
    distributor
    plugs
    wires
    Any ideas on what to check or what u may think is wrong? please input
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    I would double check that the injectors are pulsing. You could have fuel at the rail with no fuel being injected.
    Recheck your firing order possibly.
    Just suggestions. :)
  3. FTPRACING
    FTPRACING Member
    was thinking pulse but dont have a meter. order was wrong but i think i have it fixed now but hard to find diagrams for the distributer order for the accords
  4. tab
    tab Super Moderator
    1-3-4-2 going clockwise. #1 usually has a mark on the cap in the form of a number or letter. If not, put the engine at #1 top dead center and look where the rotor is pointing. That's #1.
    For the pulse, I'd probably check a manual. I imagine that there is a common wire among all of the injectors, and a trigger wire. Either way, it shouldn't be that hard to check. A decent multimeter doesn't cost much.
