No start. Multiple codes after swap.
andrew88sx2
So working on a 2001 Acura teg 1.8.
Timing belt blew on old engine, valves took a beating. changed head than had a dead cylinder so said ok lets get a diff engine.
So I put in a a b18 from a 96. The only diff I found during the swap was fuel injectors and rail so swapped thos.
So swap is done and it does not start. Went over all my connections and grounds all ok. changed plugs, wires, rotor and cap. The distributor is from the old engine which was running so I figure the distributor should be ok.
Ive checked the timing belt several times and that the distributor is pointed to number one wire when cyl one is at DTC.
But here are my codes.
Any pointers or a direction to start chasing would be great .
Thanks
You sure the motor is obd2 and not obd1? 96 should have been 0bd2.
Plug wires are in correctly? Double triple extra double checked that?
