no vacume manifold
Discussion in 'Forced Induction' started by efalex, Aug 2, 2009.
  1. efalex
    efalex New Member
    Danville NH
    where do you cnnect all the vaccume lines to if you dont have a vaccume manifold?
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    he means for going turbo..like if you dont use a vacuum log/block how do you run all the sources you need?
  3. Briansol
    You just Cut a hose and put a T into it.
  4. efalex
    efalex New Member
    Danville NH
    so u u cut a hose and run a t off it and connect the other nesscary lines? helpful shit to i did a lil research and u can run some of the linesto the intake manifold
  5. Briansol
    Thats what ends up happening... you end up needing 3-5 sources depending on gauges, and thus, the vac. manifold make sense.
