no vtec due to good oil???
Originally posted by rsaeini@Oct 9 2003, 12:03 PM
PS- Royal Purple is good and all but i will stand by my Castrol full Synthetic oil everytime.
you said it castrol rocks :withstupid:
Originally posted by rsaeini+Oct 9 2003, 09:37 AM-->
@Oct 8 2003, 11:50 PM
also, why is my speedometer flick up and down when i drive normal??
check your speed sensor for that. it's located on your tranny, near where the passenger side axle goes into it.
mine did that before cuz i got some coolant on it while doing my swap. i took the plug out, dried it, held a blow dryer(on cool setting) on it for like 15 minutes and it fixed the problem.
just a thought but if the ecu is not getting the correct speed readings wouldnt that keep vtec from engauging also. try cleaning it like posted and c if that helps
