Non starter after compressioin test
Status
Not open for further replies.
gaz4974
Hi guys,I have a big problems. Hope you can help I have a 1992 lude with a h22a engine its a jap import to the UK.I have just brought it all was fine until I decided to do a quick service like you should, bad idea!! took plugs out and cranked the engine over to do a compression test on each cylinder. 150 on each !! Put plugs back in and tried to start it to warm up the oil, NO GO.No spark at the plug also the plugs are dry when I pulled them back out so there cant be any fuel from the fuel rail but there is fuel coming out from the filter,Has anyone go an ideas what else could be wrong as I have checked the earth wires? Also I cant find the little block that you need to jump to get any error codes looked both sides under the dash is it part of a connection or is it just open ended? Thanks
Status
