noninterference engine?
Discussion in 'Integra' started by necessaryevil, Sep 12, 2009.
  1. necessaryevil
    necessaryevil New Member
    in da 503
    ok my friend has a '89 ls with the dohc d16a1 that he is selling, the only thing wrong with it is the timing belt broke doing about 75mph on the freeway, and im wondering if the d16a1 is a noninterference engine and i can just throw a new belt on and be done.
  2. klyph
    klyph Dismember VIP
    North Pole, AK
    Yes it is an interference engine. The engine is probably toast, but I've heard of interference engines surviving timing belt failures.
  3. necessaryevil
    in da 503
    is there any way to tell without tearing down the engine?
  4. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    get the timing right put the belt on and start it, if it explodes then you need a new...well pretty much everything, but if it's fine then you're good.
    you might as well play it on the safe side and just pull the head, no reason for putting money into something that's not worth it
  5. necessaryevil
    in da 503
    i just dont want to pay for the thing without knowing, someone said i could do a "leak down" test before buying i just have to turn everything by hand
  6. klyph
    klyph Dismember VIP
    North Pole, AK
    A leak down test would indicate if it has bent valves, but you'd need to put a timing belt on it to do a leakdown test. They have fiber optic cameras that can be fed down the spark plug hole, that would be the only way to tell without pulling the head or installing a timing belt.
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    most likely didn survive..you could alays buy i pull the head and replace it or the valves..if it didnt chunk up he pistons and or the actual head
  8. Bobby17772
    Enfield, CT
    and plus it would give you a good reason to rebuild it
