noob b16a swap help
Discussion in 'HYBRID -> ED-EF / DA' started by jgcivc22, Aug 15, 2009.
  1. jgcivc22
    jgcivc22 New Member
    this is my first swap. i have a 91 civic hatch std, got the engine out now from a wiring stand point is there anything else i have to to other than the four wires? because i was comparing the plugs from the 2 engines and one is way diffrent. so is there anything you need to change for the b16a i'm kind of stuck.
  2. Korax
    Korax New Member
    Western PA
    The one that is way different goes to the distributor? There are a retarded amount of write ups on this subject man. /search
  3. D16SiHatch
    D16SiHatch New Member
  4. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    Unless it's an Si, right? I don't think he said so in his beginning topic...
    Also, it depends if he's staying OBD-0 or going to OBD-1, on how much work he's actually gotta do...
  5. jgcivc22
    jgcivc22 New Member
    i'm staying obd-0 i have a pr3 ecu
  6. D16SiHatch
    correct. however he said it was a std model, which is dpfi.
    to OP: staying obd0 is fine, but you will still need to convert to mpfi. as well as run the wires for vtec solenoid, vtec pressure switch, and knock sensor.
    plus there is the issue that the pr3 will be looking for 2 oxygen sensors
    Tech - Closed Loop
