pull back the carpet on the passenger side of the car under the dash, you may have to remove the plastic piece (the kcik panel) pullit back you'll see a big piece of metal that covers the ECU, and also a small hole... turn the key to the ON position, dont start it and it will flash the code at you. You do know the codes correct?
