NOS confusion
Discussion in 'General Tech and Maintenance' started by EF9_boy, Jun 21, 2009.
  1. EF9_boy
    EF9_boy New Member
    TX
    Is NOS forced induction or not?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    no
  3. 97hatch
    97hatch ?
    Anderson IN
    its a depateable topic but most say no and some say yes as you are forceing extra oxygen in the engine
  4. jamesA
    You're injecting extra fuel into the engine.
  5. Kanned
    Kanned Beast
    Florida
    A big fat x2 from me.
  6. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Nitrousoxide (NOS is a brand, dude) introduces extra oxygen into the chambers to burn so you can add more fuel and get a more powerful combustion, it's a great power adder if you don't use too big of a shot for your build or use it at low rpms. That's my opinion.
    fixed :)
  7. Magana559
    Magana559 The Warden
    fresno Ca
    Oxygen :fr:
  8. Magana559
    fresno Ca
    God damn it! NO NO nitrogen is a noble gas! It DOSE NOT BURN!
    when nitrous oxide is heated it releses the oxygen atom. More oxygen in the same volume allows you to burn more fuel, More fule being burnt in the same volume equals more power.
  9. jamesA
    If you stuff more oxygen into the engine, you have to inject more fuel in or you run lean. So don't call me a ricer, k thanks.
  10. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Yes! It is. You can believe what you want, but any sanctioned race event you go into with nitrous you be classified as "forced induction".
  11. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    I thought sanctioned events just classified it as a "power adder." In Pro Mods your allowed one "power adder"; Nitrous, Turbo, or a Supercharger. I'm not saying its either because I dont know for sure but I've never seen NHRA, IHRA, or anyone else call it forced induction.
    Edit/Augmentation
    From the Wiki...
    After reading that, Im leaning on forced induction. I know Wikipedia can only be taken at face value since its user edited but it sounds correct to me.
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    im going with forced induction..
    just due to the simple fact that you need bottle pressure for the nitrous to work effectively..what is pressure??? FORCE,,whats happening??? its being INDUCTED...
  13. K2e2vin
    Raleigh, NC
    I don't drag race :p But yes, "power adder" is the same thing as "FI"; as in all instances you're forcing more air/oxygen than the engine would normally pull in on it's own.
  14. 93civicracer
    Texas
    Damn thanks for the correction, post edited.
