reckedracing said:what type of kit?
wet or dry?
if you're looking for that much HP you better be going with a wet kit
reikoshea said:call it nos again and ill break your fingers
i wouldnt recommend running that shot on a stock honda...definitely not a b16. Your CR is so high that you might cause some problems. Id stick with a 50 shot DPI style just to be safe.
Your gonna need a lot more than nitrous to hit the 12 second mark though...thats a hefty goal without a turbo or an h22 (with 11-12:1 CR, Big Cams, and a Lot of Nitrous)
wet or dry?
most of the stuff here is just a waste of moneyok i'm trying jasma headers msd ignition stripped my car of some weight a spoon vtec controller and hot wires with a full tuned exhaust with 2 1/2 inch down pipe isn't that good enough oh yea and a powerflow upgrade
