Nos
ZAC
Member
What would be a good compression ratio to run a 75 shot of nitrous.I know that you need low compression for a tubo but I'm not sure about n20.
It's in a b16a1
I'd think you'd still want a decent compression,since your not going to be squeezing all the time.Unless your talking about a track only vehicle that only see's full throttle racing.
the biggest thing with nitrous tuning isn't your compression. It's your A/F ratio. you can squeeze a big shot with high compression. You just need proper tuning.
so i will be ok with 11.0:0c/r and a 75 shot as long as I get differnt rings and pistons ? If I'm missing something please let me know what else I should do
Thanx for any help
Yea, i'm about to do the same thing. my friend talked me into buying nos, only because my car is slow, and i don't wanna put up the money for a turbo right now. But on my Z6, the comp. ratio is 9.2. would a 100 shot be ok on a wet system????
I'm not one of these experts, but I would say its to much (unless you just wanna exuse to do a swap)
its all about fuel and tuning. and a wet shot kicks in a LOT harder than a dry/fogger does
75 fogger = 55 shot wet i would say as far as the power it seems to put to the ass dyno
just upgrade your fuel system a tad and get some different plugs and wires. you don't need to rebuild your engine for a 75 shot, it's perfectly safe if you can give your engine ample fuel. :)
