Not a Dumbass, but...
Discussion in 'General Tech and Maintenance' started by EGLSHB, Dec 1, 2003.
  1. EGLSHB
    EGLSHB Senior Member
    Do you have to drop the tank in a 94 Del Sol VTEC to change the pump?
    or is it accessed by removing the rear cargo compartments?
    anyone know?
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    I know on a 92-95 civic that its under the rear seat, and should be accesible without dropping the tank, I hope this helped.
  3. EGLSHB
    as best i can figure, it is either under the little storage thingy in between the seats, or i am gonna have to drop the tank... i got a 255 walbro for it, but i don't want to do it at home if i need to drop the tank...
    if that is the case, i will put it on a lift at my brother's shop
  4. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    i would imagine you get at it through the inside of the car. remove all the plastic and what not behiind the seat, should be there. please post how you went about it when your done, im gonna be doing a fuel pump with my swap later, so it'll be good to know for sure.
  5. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    then the same should go for the del sol
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    del sol is a 2 seater eh!
    lol
    but to answer the question, yes you do have to remove the rear center compartment thingies (must remove the side parts first though) to get the the fuel pump.
  7. E_SolSi
    remove the whole center piece (shift area and arm rest) then the rear compartments will come out
    there will be a kidney shaped metal panel with some wire going through it ... take that off
    the pump is under there (round plate with about 8 nuts)
    pull that out... the pump is attatched to it
    take the stock pump off .... put the new one on
    do what you just did in reverse to get everything back together
    (i just did mine not too long ago)
  8. TurboMirage
    :withstupid:
    same goes for 92-95 civic, but all you gotta do is pull out the rear seats instead of all the console trim.
