Not a Honda question. ~How much does a cast iron big block V8 and tranny weigh?
Discussion in 'Other Vehicle Discussions' started by SlushboxTeggy, Jul 13, 2007.
  1. SlushboxTeggy
    NJ to MA to CA
    Like the title says, about how much does a cast iron big block V8 and tranny weigh? I realize that weight will vary from one to another but I'm just looking for a ballpark.
    I'm about to buy a shell with a blown engine in it that I would need to ship or tow. Well the vehicle sits at a little over 6000 lbs right now which I have recently realized is damn near impossible to tow without a serious truck. If the engine and trans are a substantial weight, I might be able to pull it (It's junk strap metal at this point anyway) and tow it somewhat more easily. So about how much does a cast iron big block V8 and trans weigh?
  2. E_SolSi
    it weighs exactly ___lbs more than my nuts
    get that number right and theres your answer
    honestly i have no fucking idea how much it would weigh.... but try checking the shipping weights on something like Jegs or JCWhitney... that might get you a ballpark #
  3. ScrapinSi
    ScrapinSi Senior Member
    Dry weight of the average Big Block Chevy is about 600-700 lbs dependign on heads/intake/carb...
    Tranny is probably 150-250lbs depending on type of tranny.
  4. totalburnout
    NJ
    Indeed, its somewhere under 1000lbs, probably around 800lbs.
  5. jamesA
    Too many different SB and BBs to give you exact numbers. Quite a few SB/BB Chevy's aren't cast iron.
    What vehicle did you get and do you have any numbers/info on what kind of engine it is?
  6. SlushboxTeggy
    NJ to MA to CA
    That part is kind of going to be a suprise. I feel like I'd get flamed about this build before I take some tools to it. I'll tell you that its not a chevy.
    But I like the idea about shipping weights on Jegs or JCW.
  7. Jeef
    Jeef NO MA'AM Moderator VIP
    Caddy or an Olds?
  8. jamesA
    So what the hell is it?
  9. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    why is this in the auto multimedia forum? :)
  10. jamesA
    It's not! :p
  11. Celerity
    Celerity Well-Known Member
    a TH350 weighs closer to 300 lbs than 200. The engine, complete, is well over 500 pounds.
  12. klyph
    klyph Dismember VIP
    North Pole, AK
    If he's talkin big block the trans will probably be a TH400. That is if it's a GM
  13. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    Big block 454, 635lbs th350, 265lbs.
