Hey fellas,
I recently did a B16 1st gen swap into a 91 Civic Si. And I'm not getting any fuel to the fuel lines. I checked the fuel pump wires for power w/ a test light and got nothing. What can it be? Fuel pump relay? There is no fuel pump fuse for it (that I can find in the fuse locations.) Help. All the sensors are hooked up except vtec.
When I'm using the PR3 ecu (JDM DOHC) I get the engine turning over but doesn't run.
When I'm using the Stock Si ecu I get a buzzing sound coming from the main relay. I checked both ecu's on another 90 Civic and they both work and the relay also works in the other car.
Any Clues?
Joe
Any Clues?
Joe
